Newbie: cannot chose network folder inside ffs
juldrew
Hi, I'm pretty new to ffs. It's a great tool for me -as long as I stay within my local pc.
I'm running 6.7 on 8.1 pro.
I have a synology nas and mapped its drives in my Windows Explorer.
The problem is: inside the ffs program I cannot chose the mapped drives because they are
not shown in ffs. Also, if I try \\Diskstion\video (which works in Explorer) -it doesn't in ffs.
I already gave ffs admin privs, but I don't know what else I can do to make those Foldern shown
and usable in ffs.
Anyone could help? I'm sorry, if it's something obvious. I didn't find a solution using the search fuction.
Thanks,
Julian.
norbking
and usable in ffs.
Thanks,
Julian.juldrew
If the file path isn't to long you could type it in manually and see if it works.
Hope this helps.
