One step forward, one step back
bobschneider
I really like being able to see the copy direction, but the button that switches left and right sides has gone: it has turned into a button to switch view between copy direction and more recent files. OK you can change copy direction easily for individual files, but there seems to be no convenient way to change copy direction for all files at once.
Please can I have my left/right switch button back.
Hi Bob,
You can change several lines at once by selecting multiple rows in the middle grid. (Works for temporary filtering as well as for all sync-directions)
Moreover the switch functionality is not lost. It's in the middle grid context menu.
I try hard to keep the GUI lean, so I decided the switch view button be more important than the switch side: The former represents the two basic usecases of the tool: comparison and synchronization.
Best regards, Zenju
bobschneider
Thank you for the quick reply Zenju.
I didn't think to look for a context menu for the middle grid. Doh! My bad.
Keep up the good work,
Bob
