RealTimeSync
Is there a way to specify the delay for RealTimeSync from the command line?
No, it's the same approach like for FFS: config files are specified via
commandline while configuration itself is passed within these files.
OK. So is there any way to specify the delay time aside from manually changing
it in the GUI of RTS?
Delay needs to be configured from GUI. But as these settings can be saved as
*.ffs_real and then executed e.g. from a *.bat/cmd file this shouldn't be much
of a restriction.
of a restriction.
I see what you are saying now. That's perfect. I didn't realize I could save
the config in RTS, I was looking in FFS. Dang your good!
