what about a "Shutdown after finish" feature? OR how it can be accomplished?
I like your workings! Thank you!
Maybe it can be done via an addition to the batch caller - if your application
CLOSES after finishing !?
Greetings from Germany
maybe I can help you here. Small shutdown tools exist already,
so it is not needed to include shutdown in FreeFileSync.
You can accomplish this with a simple batch file.
First save the sync job as FreeFileSync batch job, then create
a batch file in the FreeFileSync folder:
- launch ffs with "start /wait freefilesync.exe mybackup.ffs_batch"
- then use a shutdown tool i.e,: "shutdown -s -t 10"
That is all, shutdown gives you a ten sec timeout to abort it.
regards,
fred
regards,
fred
grobbla is right, simply as this ;)
