View folders/files that are to be deleted?
greenmoose
Is it possible to somehow filter the files so I can view which files/folders
I can only see the summary icon where the trashcan indicates the number of
deletions, but I see no way of actually viewing the files/folders that will be
deleted.
Thanks.
Sure, just use the view filters at the bottom of the screen to show only to be
deleted files.
greenmoose
Hrm I don't have that filter option, all I can see is "Hide files that exist
on right side only" (or left side respectively).
No "show files that will be deleted" filter...
[404, Invalid URL: http://img132.imageshack.us/img132/3280/tempjg.jpg]
(I'm using v 3.6)
FreeFileSync offers two views on it's data: 1. Comparison result and 2. Sync
preview. You can change it via the file menu.
greenmoose
Oh... Did never notice that menu option for some reason. Thanks.
