Sorry, I must be blind somehow. Where do I find the portable version of FFS?
What I did find is the .exe, which I presume we've to install it.
Portable Version of FFS
You can select portable installation directly in the installer as an option.
I see. Thanks. I didn't know the .exe is actually an installer.
I am trying to install portable, but it prompts for elevation (Windows 7 & 8). I know I can tweak my UAC settings, but this defies the idea of a portable install. Would you be so kind to publish the files as a ZIP (or any other) archive?
in the Portable version 6.3 there is (I thing) bug. When I rename program folder, and then run the FFS, loading of the program ends with error message "Cannot get process information. Error code 3: Cannot find specified path (Create file)." My opinion is, that portable version should have to use relative paths to access program files. Same problem is with loading ffs_gui configuration files - when configuration file is stored in program directory, in the GlobalSettings.xml is stored full path (so when you move program folder, you must load configuration file again to program). This last thing can be fixed by deleting path and leave only configuration filename.
