FFS is so great to sync! But when the first trying to backup my data from laptop to mobile hard drive I met the above problem "Windows Error Code 5 and 1300"
I tried many times and solved it anyway. Actually just right click the shortcut on desktop(or the FreeFileSync.exe in install folder) and select RUN AS ADMISNISTRATOR.I include a figure here you all can see that if we dont select it FFS will run under low permission user. OK aLL is perfect!
Hope this is helpful for guys with that problem.
How to solve "Windows Error Code 5: Access is denied/Windows Error Code 1300: Not all privileges or groups referenced are assigned to the caller.
