in my photography workflow I have camera raw files *.cr2 that are converted into *.jpg files in another folder, e.g. raw/IMG_4279.cr2 -> jpeg/IMG_4279.jpg
I walk through the jpg folder and delete the bad ones (this is faster than with the originals). Then, all *.jpg files missing from the jpeg folder should be also deleted in the raw folder *.cr2
An equivalent problem would be:
Folder A contains *.txt, folder B contains *.txt.bak
Now delete all .bak in B that do not have an original in A
Can this be done with FreeFileSync?
Thx,
Juergen
.cr2 and .jpg : synching image files with different extensions
Servus,
this may be a bit late, but what about a batch file?
Here is an example that does what you want. If there are spaces in the path/file name, you will need to use apostrophes in the batch. The example does not actually delete, it just echoes.
Save as example.cmd
@echo off
set B=test
set A=.
for /f %%i in ('dir /b %B%\*.bak') do call :chk %%i
goto :end
:chk
echo check: %B%\%1 -- %A%\%~n1
if not exist %A%\%~n1 (
echo delete %B%\%1
) else (
echo preserve %B%\%1
echo.
goto :eof
:end
Save as example.cmd
@echo off
set B=test
set A=.
goto :end
:chk
echo delete %B%\%1
) else (
echo.
goto :eof
:end
