Can I access the changed file list from command line
huwang
First of all, FFS is a great tool that greatly eases my daily sync job. I set it up to run automatically w/o any issue. However, there is a thing. If I want to change the Last Modified Time for all changed files, can I include this step into the batch file? I know it can be done in GUI as an external application (touch.exe "%item_path%"). But I really don't want to manually run FFS everyday only because of this. I searched around, but still couldn't find a good solution.
Thank you
