Unreadable text at 150% Windows setting
I use a 27 inch monitor with a 2560x1440 resolution and to keep everything readable i used the 150 % text option in Windows 7 but it results in FreeFileSync in some unreadable text: http://www.afbeeldinguploaden.nl/photo/view/69545/PwKc. It would be great if there was a solution for this.
It seems you changed the font size after starting FFS for the first time. Therefore FFS just loads its last-saved layout which is for regular font sizes. You can update the layout manually by right-clicking between compare and synchronize buttons and select "Default view".
While testing with 150% font sizes I've found and fixed a few layout errors related to standard button sizes. Let me know if there are any other issues left:
[404, Invalid URL: http://freefilesync.sourceforge.net/FreeFileSync_6.6_beta_Windows_Setup.exe]
Who, thats fantastic. Its seems that's everything ok now.
