Temporary Files
aigorv
Thanks for the program.
Whether it is possible to make so that temporary files in temporary folders which are created by the program, didn't get to a Recycled ??!
The Recycled is very quickly hammered with your files, and it is impossible to find my necessary file.
(Global settings: Copy to tmp files is disabled.)
It is very uncomfortable (((
And more ...
Files sync.ffs_db well be stored in the folder of the program FreeFileSync.
In synchronized folders to the user they are not needed, and these files are constantly having to remove yourself.
Thanks.
I'm not sure what you mean. There is some problem with temporary files?
If you have to delete the sync.ffs_db files, then you're using the wrong sync variant. Try "mirror" instead.
aigorv
If you have to delete the sync.ffs_db files, then you're using the wrong sync variant. Try "mirror" instead.Zenju
Yes, there is some problem.
These temporary files do not need me in the Recycled,
I use the Recycled to remove the files I needed in next time, which is then reduced.
Now they are hard to find - all culled files FreeFileSync.
... Anyway, the Recycled is designed for a different purpose than the storage of files FreeFileSync.
I am using the correct sync variant.
I delete the files after all synchronizations when I need to give the folder to another user.
He does not need this garbage ((
Thanks.
Then choose a different "deletion handling".
If you delete this file, then a two-way sync will not work correctly. If however you think you get the results you want, then you are better off with a custom sync variant that just copies files both ways and doesn't need a database file.
aigorv
I do not understand very well at English, my native language is Russian.
Sorry if something is not said so.
I'll try again.
1.
With the Recycled like figured out, thank you.
There was not quite clear what files is set to "Delete Files" in the Russian translation of thought to the core files, it turned out - to be temporary.
I thought that the temporary files should be removed without a trace and without settings - this is obvious. I was wrong.
2.
I understand that!
I do not delete them until a few days looking for synchronization.
But in the final version of a folder, a month when the synchronization is no longer needed, they have to find and remove.
I understand that the files needed.
I want to say that to keep them in my data - it is not good.
They should be stored in the program folder.
If you feel that the currently translation could be improved, feedback is much appreciated: viewtopic.php?t=1452
Okay, understood, this is not a bug report, but a feature request.
