Filesync 7.6 wiped all my files
After installing version 7.6, run the application to mirror all the users folder. However, during the process he gave a crash and the application wiped all my files in this folder without making a copy. I lost all my files. I tried to recover the files with three different programs without success. what to do?
When an application crashes it cannot delete any files, the process is essentially dead, doing nothing anymore. In the case of FreeFileSync there is no point in time where a crash could lead to data loss since files are overwritten only after the replacement files was copied correctly (the feature is called "fail-safe file copy", enabled by default).
However what FreeFileSync cannot entirely prevent are incorrect configurations, like confusing source and target directories (however even in those cases it will show a warning about a "significant difference" of the data sets).
In these situations the options for data recovery depend on the file deletion settings:
https://freefilesync.org/faq.php#restore-files
