Graph bug
when biger file (outlook .pst file for example) is synchronized, graph is not 'moving' ... see picture.
This seems to be due to the VSS service taking a volume snapshot that is needed to copy the locked file "Outlook.pst". Which version of FFS are you using? If you can reproduce this situation I'd like to investigate why the corresponding message "Creating a Volume Shadow Copy" is not shown.
Hi
I've the same problem, I use FFS 8.2.
Impossible to sync .PST from the V8 update.
Many thanks for a solution.
Best regards.
Best regards.
