Run RealTimeSync once per drive insertion
jetfission
I have RealTimeSync set up so that it automatically mirrors data from one folder on a computer to a folder in a drive when the drive is inserted. Is it possible to setup Real Time Sync so that once it finishes mirroring data, the loop stops until the drive is removed and mounted again? The folder mirrored is actively being populated with data, and I don't want to have to be standing by while it copies just to remove it at the right second, before it starts copying again.
Thank you!
jetfission
I'm out of options here, if anyone knows a way that would be great!
georg_m
i've got the same problem
Why use RealTimeSync here?
Why not use Autorun to run FFS directly upon drive insertion ...
georg_m
because i haven't thought about that before.
it works. thanks.
i have to use a tool called autorunner though, because win7 doesn't support autorun.inf.
