when I try to install new release 6.15, the installer shows a message "Installer integrity check has failed". I've downloaded again from majorgeeks.com or from https://freefilesync.org and error does show.
problems?
Install Error
Same problem here. 7-Zip tells me that the files in the "Bin" folder (and the file "uninstall.exe.nsis" in the root folder) are corrupted.
UPDATE:
I just downloaded the installer from "winsoftware.de" (I downloaded it from "majorgeeks.com" before) and the extraction works now. The size of the installer from "majorgeeks.com" was somehow much smaller (4 MB vs. 11 MB), so maybe "majorgeeks.com" made some error and uploaded a corrupted file.
UPDATE:
it is working now. i've downloaded from majorgeeks.com!
