FFS writes always changes the Folders time modified to the current date, which is not useable. It does work correct under Windows ... do I miss something?
Happy Sync!
Osx time stamps settings
Are you talking about FFS preserving the folder creating time when copying a new folder on Windows?
Hi, I meant within OSX, a FFS sync job is not preserving the modified time stamp when creating new folders, only the time created stamp is preserved. /i.e/ if one does make a copy within OSX (not with FFS) the respective time stamps are preserved!
It's the other way round: On Windows a FFS sync job is not preserving the modified time stamp when creating new folders, only the time created stamp is preserved. On OS X on the other hand, currently neither folder create nor modification times are copied during folder creation.
Ok, you´re right ... its confusing. May I request to maintain and sync the original folders time stamps from and to all plattform, please! Its a genius programm, happy sync!
I've added support for copying the folder creation times on OS X, too.
