I'm finding that my backup speed slows down when I minimize FFS to the notification area.
Using Mac 10.10.5.
FFS v7.9
Backing up from one external 5900 RPM drive to another external 5900 RPM drive both over USB 3.
Scenario:
I observe backup speed at 140 MB/sec. Speed stays consistent for 1 minute (just watching to see if there are fluctuations in the speed). I then click the down arrow button to minimize FFS to the notification area. Then I wait 10 seconds and click the FFS icon and select RESTORE and the backup speed is around 115 MB/sec. Once restored, speed jumps back up to 140 MB/sec after a few seconds.
Question:
Is the speed slower in the background or is it just slower when restoring FFS from the notification area?
Backup Speed Slows Down when Minimized to Notification Area
When FFS is minimized to the OS X notification area its process type is changed to background processing mode in order to hide the dock icon. On OS X this seems to have the unintended (at least from FFS's perspective) side effect of also lowering the resource priorities of the process.
Thanks for explaining Zenju. I will minimize the windows to the dock instead, it seems to keep the same speed. :) Thank you
