Slow Transfers via WAN
screege
Hi I juste tested free file sync and I think is great, my problem is that when sending files to a remote sftp server I only get around 2-3 mbps, when uploading the same files with filezilla for example to the same server I get 20 mbps which is accurate to my Isps speed.
Is there anything I can do to correct this?
Regards
Try the new 7.10 beta with significant SFTP speed improvements:
http://www.mediafire.com/download/v7ijmm38v85c9gb/FreeFileSync_7.10_beta_Windows_Setup.exe
screege
Hi thanks downloaded and installed it now I am getting between 4-5 mbps still not getting the full juice 17-20 mbps =o(
Regards
screege
Hello sadly no I am only getting between 4-5 mbps, my connection currently supports between 17-20 mbps and I get them with filezilla via SFTP
Regards
