Comparison of copied files wrong?
I just copied a large set of files from one computer to another (15G), but when I compare them it says that not one of them matches and it wants to replace everyone of them to mirror sync. What is going on here?
I have tried just comparing the size with the same 100% missmatch.
If the file size is different, then the comparison is correct in that the files must be different. Generally this sounds like a hardware problem with the target device.
