no progress windows or tray icon on scheduled tasks /win7 64bit)
sweetman
Hi all,
First of all: thanks for this great utility!
I only have one problem with it: when I run a scheduled task nothing seems to
happen: no progress window or tray icon (if ffs is minimized).
I just know that synchronization is in progress by seing freefilesync.exe in "windows tasks" window and the ram used changes slightly every second.
Is there something to do to fix this?
TIA
tony
drghughes
Check the options that you chose when you set up the batch job: https://freefilesync.org/manual.php?topic=schedule-a-batch-job
I get a FreeFileSync window for all my batch jobs which I'm pretty sure have the settings shown in the first screenshot.
