[BUG] installation fails on windows 7 64bits
The installer of v8 just fails in copying all exe files with an error when moving them.
What error do you see during installation?
Same problem over here (Windows 7 Pro, 64bits). Installation fails with this message:
Cannot get process information.
Error Code 3: System can't find the path. (CreateFile)
((Error Code 3: Das System kann den angegebenen Pfad nicht finden.))
This problem should have been fixed. Can you try with the following version:Same problem over here (Windows 7 Pro, 64bits). Installation fails with this message:
((Error Code 3: Das System kann den angegebenen Pfad nicht finden.))mjates
http://www.mediafire.com/download/nthu36ixg9tl2rm/FreeFileSync_8.1_beta_Windows_Setup.exe
Works a treat now. Thanks for the quick reply!
