FFS on Windows - "Synchronizing/Completed" dialog - Alt-Tab problem
echtatze
When I use Alt-Tab keys at a running or finished synchronization, to change the focus to another application, I have no chance to reactivate the "Synchronizing/Completed" dialog without using the mouse.
By using Alt-Tab only the FFS main window can be (re)activated.
When I close this then by using "Alt-F4", the "Completed" dialog still stays open.
Closing this dialog now causes a crash of FFS.
It would be better/correct having the (already modal) dialog being activated when using Alt-Tab.
Then all would behave as if I never switched the application.
Regards,
Atze
echtatze
No reply here?
wm-sf
No reply here?echtatze
Some time has passed, the world has spun around a bit but you seem to be in exactly the same place as before.
Most people would expect your version of FFS to have changed in the last year or so
echtatze
Whatever you want to say with your philosophic approach, even version 7.1 behaves like I described.
wm-sf
Whatever you want to say with your philosophic approach, even version 7.1 behaves like I described.echtatze
you get a crash? after all these years?
echtatze
Please?
echtatze
@Wm: Please, what was your intention for posting?
