Suggestion - File movement on target for cloning
Sulas
Hello Devs,
I want to make a suggestion.
As I've seen so far, files that have been moved on the source get copied again and then deleted on target in the old path.
It would be much better, when they get moved on the target too instead of copying again.
This would save a lot of time and i think it wouldn't be a big problem to implement this.
Would be nice, if you could consider that.
Greetings, Sulas
