Can anyone advise me that will FFS be used to sync data associated with particular applications? Usually these are stored within the application in program files. How can I do that? Thanks.
Sync data associated with particular applications
The data associated with an application will usually have a specific file extension, e.g. .doc for Word documents.
You can use the filter function https://freefilesync.org/manual.php?topic=exclude-items to only sync those files.
