sftp Error Code LIBSSH2_ERROR_SFTP_PROTOCOL
Miha
Can you help me identify where the problem
I can upload/sync to server using sftp option MIRROR (hard drive -> sftp server)
But if I want to download with the option MIRROR (sftp server -> hard drive)
I get error msg
Error Code LIBSSH2_ERROR_SFTP_PROTOCOL: Failed opening remote file LIBSSH2_FX_PERMISSION_DENIED (libssh2_sftp_open)
This happens only on certain files.
Miha
Did identify the problem
sometimes ffs uploads a file but without any permissions.
Because of that when I try to download file server will not allow it.
I did try to upload it with filezella and permissions are there so I guess this is a ffs problem.
Can you fix this?
FreeFileSync uploads all new files with read-write permissions (0666) and folders with read-write-execute (0777). Is there a problem with these defaults?
Miha
problem is that generally it will do 0666 or 0777
but I did encounter 9000 files from 80.000 files who had empty permissions
it looks like it sometimes skips this step
Wim
i'm also having similar problems: files that appear to have permission 0000. the sftp server i'm uploading to / downloading from is a laCie Cloudbox. is there any way to review in logging what happened and why?
kartom
We are running FreeFileSync v 9.3 and it's not creating files with permission 666 for us. The new files created by FreeFileSync will get permission 644, and that is a problem for us.
On our system all new files are created with permission 664, but when we are using FreeFileSync for syncing all new files get permission 644. Is there a way of changing the default behaviour or could there be
something in our setup that makes FreeFileSync create files with the 644 permission?
xurc
I got the same error
In case when I wanted to compare folders (local to remote via SFTP )
It turned out that my ISP changed IPv4 into IPv6 and that was the issue. When they changed back to IPv4 synchronization works fine. I believe this must be problem with the library that FreeFileSync uses to connect together with IPv6
It turned out that my ISP changed IPv4 into IPv6 and that was the issue. When they changed back to IPv4 synchronization works fine.xurc, 31 Aug 2017, 07:47
In general IPv6 should work fine with SFTP. Do you have an IPv6 test server that reproduces the connection issues?
xurc
In general IPv6 should work fine with SFTP. Do you have an IPv6 test server that reproduces the connection issues? Zenju, 01 Sep 2017, 13:39
Now I don't have. Actually I really don't know exactly whether the problem was with server or client. It worked fine until some day. I got the error as above then. I tried to change connection settings but nothing works. After a while I realized that on my router (provided by ISP) protocol version is switched to IPv6. So every machine behind the router received new IP adresses (IPv6). When I asked ISP to change it back to IPv4 synchronization started to work again. I can't change protocol by myself so I can't test it. I need to call to my ISP, but I would rather not to do this, as many other services, that I use in my network, simply does not work.
xurc
I would like to back to this problem. Now I have reproducible environment. What I'm sure is:
1) The error is: Cannot open folder "sftp://xxx.ovh.net/".
LIBSSH2_ERROR_SFTP_PROTOCOL: Failed opening remote file - LIBSSH2_FX_PERMISSION_DENIED [libssh2_sftp_opendir]
2) When using FileZilla & WinSCP the connection works, so login and pass are valid
3) my new ovh server works on both IPv4 and IPv6
What I can do to get more verbose logs from the error?
Do you have a test login that allows to (at least temporarily) reproduce the connection issues from my end?
xurc
I can arrange that, but I would not like to public it here :) and I don't see that private messages are available. Please contact me via e-mail I used on this forum (I assume you as site admin has privileges to read that)
xurc
This isn't an IPv6 issue: You're trying to access an FTP server via the SFTP protocol! ;) Zenju, 29 Oct 2017, 17:09
SFTP is available on that server as weel. I can connect via SFTP using FileZilla and WinSCP, but I can't with FreeFileSync.
SFTP is available on that server as weel. I can connect via SFTP using FileZilla and WinSCP, but I can't with FreeFileSync. xurc, 29 Oct 2017, 17:18
The problem is that FFS is not allowed to access the root folder "/". If you'd manually enter the server directory "/home/username" everything works fine. So this is mostly a problem of the SFTP folder picker, which should be improved, e.g. to consider the working directory after login rather than always start form "/".
