Transfer file and folder permissions
regis_1
I checked the box for "Copy DACL, SACL, Owner, Group" but when I view the security properties on copied folders and files none of the original permissions are there. Is there something else that needs to be done to get the permissions to transfer?
Do you consider permission inheritance?
regis_1
Inheritance is disabled on the folders.
