Hi to all,
I've already searched the forum for the named issue but didn't find any solution for it.
Therefore I hope somebody can help me out.
I run FFS as a recurring task configured with a batch file to sync backup files a local disc to a USB disc
This worked perfectly for months until now.
Sync still works fine but no logfile is written any more.
Even the batch I call afterwards to compress the backed up files, is run
but at present I have no option to see wheter the backup finished without errors or not.
Strange thing: before the issue ocurred, I did not touch the configuration.
Just from one day to another logfile creation has stopped.
I checked the log folder; it's all fine and writeable.
I even restarted the machine but no luck.
Any help is appreciated
Best regards
sysop
Logfile creation has stopped working
Run the ffs_batch job manually and check if you see errors in the results dialog.
On my research for a solution I already did so.
There were no errors; there was no log.
Strangely strange: this weekend the task ran, like it does every week and the log was there.
As this hasn't been the case for the last two weeks, all this seems a bit myserious to me.
