Have a batch file on a Windows Server 2008. I then create a shortcut to it on several machines that people will run occasionally. But after running a couple times (not sure how many) I get the following error:
Configuration file "directory/filename_batch" is incomplete. The missing elements will be set to their default values.
The following XML elements could not be read:
<FreeFileSync> <MainConfig> <Comparison> <TimeShift>
If I go back in and resave the batch file from the configuration file it works just fine again for a while.
We are all running FFS 8.0 on PCs with Windows 7 and 10.
Jim
Error in batch file after use.
Such warnings usually come up when a FFS version is loading some very old configuration file format that is missing some elements.
