Hi, I have Windows XP SP3 and I can copy files normally from my Android phone via MTP in the explorer, but I don't see it when clicking "browse" in your program (v8.1). I can't drag and drop a folder neither.
Thanks for your help :)
Can't add a folder in MTP in Windows XP
FFS's MTP implementation is only available for Windows Vista or later.
oh :(
Can I sync with FTP and/or SFTP in WinXP? Couldn't make it work neither.
If both things are not supposed to work in WinXP I would advice to report it next to where it says that works with MTP, SFTP and Windows XP.
