I want to synchronise my Exchange-database.
I get a error: Cannot read file .....
ErrorCode 32: The proces has no access to the file, because is is used by another proces (CopyFileEx).
Cannot access the Volume Shadow Copy Service.
Please use FreeFileSync 64-bit version to create shadow copies on this system.
Who knows what to do to solve this problem?
It may be a long shot, but maybe "use FreeFileSync 64-bit version" SCNR
Where can I download this 64-bit version?
You already have it. What is your operating system?
Small Business 2011 64-bits
My version is 32-bits (unicode x86)
So you're on Windows Server 2012. Which of FreeFileSync's executables are you starting?
FreeFileSync.exe
I used FreeFileSync_8.1_Windows_Setup to install it.
Can you check if you are running FreeFileSync.exe in some compatibility mode? This would explain why it redirects to FreeFileSync_win32.exe instead of FreeFileSync_x64.exe
I just found FreeFileSync_x64.exe. This gives the same problem
Thanks I will try compatibility mode later on
No, the solution is to turn it "off".Thanks I will try compatibility mode later onDerfBric
Are you sure? Running it returns "Please use FreeFileSync 64-bit version"?I just found FreeFileSync_x64.exe. This gives the same problemDerfBric
The 64-bit version gives the same error.
Cannot read the Exchange databasefile.
cannot access the volume shadow copy service
I think I found my problem.
I renamed Shadow_Windows7_x64.dll to Shadow_Server2003_x64.dll at started FreeFileSync_x64.exe
Now a Volume Shadow Copy is made.
Yes, but not "Please use FreeFileSync 64-bit version", correct? What is the full error message?The 64-bit version gives the same error.
cannot access the volume shadow copy serviceDerfBric
This cannot be the solution. You're on Server 2012, this means FFS will use Shadow_Windows7_x64.I think I found my problem.
Now a Volume Shadow Copy is made.DerfBric
The only explanation for all these symptoms is that you're running FFS in a compatibility mode lower than Windows 7. Solution then is to disable compatibility mode.
