Windows 10, Blurry Text
Known issue with some applications in Windows 10 if display is scaled. This application has this issue. Easy fix is to right click the shortcut, choose properties, choose the compatibility tab, and place a check in the "Disable display scaling on high DPI settings". I do not know why some apps need this and others do not, possibly the chosen font and how it is scaled? Also when this box is checked, the window frame slightly cuts off some of the "statistics" box in the bottom right corner. This is just a visual issue, pointing it out if there is a way to improve it for the future.
