Hi everyone,
I am new at FileSync and would very much appreciate your help on a question I have.
I am trying to compare two directories containing multiple folders, subfolders and files. The two directories contain the same document, called "Contacts", with exactly the same size and content in both directories. The only difference is that the file "Contacts" doesn't have the same date in both directories and also doesn't have the same path.
Until now, since the two files are not at the same location, I didn't manage to have FileSync compare them. It thinks these are two different files. Is there a way for FileSync to compare them and mark them as equal? In other words, is there a way to ask FileSync to ignore the path of the files and compare them if they have the same content?
Thank you in advance for your help, have a wonderful day
Compare files ignoring their paths
