I run Ubuntu-MATE 16.04 LTS and want to install FFS 8.1 to use. The PPA method fails to install; below is what I used: There doesn't seem to be a Ubuntu xenial directory in the PPA site. Terminal session in attached file.
I downloaded the "FreeFileSync_8.1_Ubuntu_16.04_64-bit.tar.gz" file and extracted the files but there is no Install script. Opening the FreeFileSync executable in the extracted files directory (in my Downloads directory) does run the application and it appears to work - but I want a launcher in my Applications Menu and the configuration file does not seem to exist (~.freefilesync). So although I have the application - it is not installed on my system. How do I run an Install so FFS is registered in my system properly?
Thanks!
