lightning bolt icon - what does it mean?!?
bromberg
What exactly does the following error message mean and what should I do about it?
"BOTH SIDES HAVE CHANGED SINCE LAST OPERATION"
i.e., will the synchronization default by using the file with the newer time-stamp?
Thanks,
Dan
kilrah
It means you need to manually choose what to do for that file.
