Small bug in v8.2
Giangi
In case there is only one new file in one side, the Overview is not populated.
I have tried swapping folders with the dedicated button but Overview is still empty...
If the new file is below the base folder, then this is the expected behavior.
Giangi
No, it was deeper at least 4 levels (I'm on phone and do not remember exactly).
Anyway I think, IMHO, that the Overview should always be populated...
That's actually a feature where single-element nodes are recursively removed for clarity.
Giangi
Can you make it optional? With the new layout (see my other request) if only Item name is shown we cannot check the folder where the file is!
Giangi
If the new file is below the base folder, then this is the expected behavior.Zenju
I have replicated the same sync and I confirm that the file wasn't on the base folder...
This the log with the exact path
___________________________________________________________________
|07/06/2016 - ParkUSB2ParkD: Synchronization completed successfully
|    Items processed: 1 (9,08 KB)
|    Total time: 00:00:01
[11:22:47] Info: Synchronizing folder pair: [<- Two way ->]
                     E:\Park
                     D:\Park
[11:22:47] Info: Updating file "E:\Park\Downloads\DVD3\DisksUti\DirSyncTools\FreeFileSync\GlobalSettings-82_w1.xml"
[11:22:48] Info: Synchronization completed successfully
I've revised the node compression function to only condense single-element file nodes but keep single-element folders:
http://www.mediafire.com/download/4c9mutrdnctor3p/FreeFileSync_8.3_beta_Windows_Setup.exe
Giangi
That is perfect!!!
