Automatic Height Folder List
pumarider
Hello Guys,
thank you for this good prog.
I have a question.
When i insert a new folder in the folder-list, the list will automaticly change the height.
Can i disabled thes function?
I need a static folder list with min 15 lines.
pumarider
NightOwl
if you mean how many folder pairs are visible, you can edit the maximum height in 'GlobalSettings.xml'
e.g. to have always 15 (if used) rows visible, edit the following line, setting it to 15:
<FolderPairsVisible Max="15"/>
pumarider
Thank you for your answer.
But it didn't work.
I attached a video for explaining.
Oh, i can't attached videos :-(
I make 20 lines and enlarge the lower window.
when i make a 21st line and the programm change the height automaticly.
Or when i start the program new, the same.
pumarider
FreeFileSync 9.10: Remember maximum number of visible folder pairs
Let me know if there are any issues:
http://www.mediafire.com/file/gyrbx4uvg1ue0l1/FreeFileSync_9.10_%5BBeta%5D_Windows_Setup.exe
