Seems to Crash/Lock up my iSCSI system
IronMike
Past FFS versions worked well but my iSCSI system locks up or crashes when I do a large operation with FFS. I rarely complete the sync anymore.
I am looking at FFS because I can run much larger Windows explorer moves or copies without any problems. Teracopy works well, too.
My system is:
An I7 with 32 gig of memory.
A Drobo B800i iSCSI drive with 34 TB Disk Space
Gigabit ethernet tieing it all together
I have tried FFS on Windows 8 Pro (64 bit) and 10 Pro (64 bit) with the same results.
I am using FFS 8.2 now. These problems started 3 or four versions back. I initially blamed the hardware, so I did not keep track of the FFS version. I still blame the hardware but you may have a clue that will help me since FFS is the least reliable program on the system now.
Any thoughts will help
Sincerely,
Michael
volker01
my expierience - from an iSCSI Storage to an Remote-Server:
i use FFS 8.2 to mirror Data from an iSCSI Storage on a Server2008 - over UNC - to an Remote-Backup-Server.
i have no problems.
Volker01
IronMike
Thanks. I rather doubt FFS is the real problem but it sure brings the problem out. I'm really fishing here.
dguy
I'm in a similar situation with IronMike. My Windows iSCSI connection which worked flawlessly a few versions back seems to get halfway (sometimes) then hangs. Very inconsistent network speeds and connection. Sometimes it works, sometimes I have to reboot machines to get a complete sync.
IronMike
I Never got it to work. Tossed the 800I (Ouch)
