Problems after upgrade
juancso
Good Morning,
With the latest application update (6.10) for Mac OSX will not let me open it giving an error.
The error says: "NSInvalidArgumentException" "launch path not accessible"
Please can you help me?
Thank you very much and best regards.
Can you post a screenshot? Did you check if the FFS program files are really accessible?
margheritoni
I have the same problem. Latest update (6.10) and OSX Mavericks 10.9.5.
The program can be launched properly just as long as the file is kept inside the original unzipped folder OR if it is moved to the desktop.
If I move the unzipped file to the Applications folder OR to whatever different location and I try to open it, I receive the same error message:
"NSInvalidArgumentException" "launch path not accessible".
Of course I would like to have it inside my Application Folder, together with all my other applications, and not on the desktop or inside my download folder.
With my personal regards
This is another symptom of the same underlying problem:
viewtopic.php?t=272
Until further, the workaround is to restart OS X or manually quit the FreeFileSync process in the OS X Activity Monitor. Then FFS will start correctly, no matter from what location.
I've created a fixed FreeFileSync beta version and posted it under the following forum thread.
Let me know if you still find any issues:
viewtopic.php?t=272
margheritoni
viewtopic.php?t=272Zenju
The new 6.11 beta version has solved that issue. Thank you for your hard work.
Sorry for my late answer. I was abroad over the last week.
With my best regards.
