FFS 8.2 for Windows doesn't install
grlscz
When it gets to "Install additional software" screen, no software options are shown, and "Next" button does nothing.
Windows 8.1
FFS 8.1 installed successfully.
Can you post a screenshot? Are you using some AV software? What operating system are you using? Anything else that is unusual about your setup?
grlscz
Windows 8.1 x64 pro Russian
No AV besides Security Essentials
8.2:
For comparison 8.1 - the header seems to be in Turkish, the contents in Russian:
I've applied a fix to the ad component of the installer. Can you download from the FFS homepage again and see if the installation works now?
grlscz
No, still the same, no changes visible.
So the empty screen and the next button not working is still unsolved with the new version?
What about this version:
http://www.mediafire.com/download/2nk9uxk4ubkin18/FreeFileSync_8.2_Windows_Setup.exe
grlscz
So the empty screen and the next button not working is still unsolved with the new version?Zenju
I switched off virus protection and windows firewall and rechecked - still the same.
With this version the dialog is in Russian, but still no content:
grlscz
On the same network, install works fine on my laptops - Windows 7 pro x64 and Windows 8.1 x64 single language
grlscz
8.3 same symptoms. Though works with /silent switch.
I've finally received a patch that should fix the crash issue:
http://www.mediafire.com/download/wqesw83fzna0bxj/FreeFileSync_8.3_Windows_Setup.exe
Let me know if it really does this time...
grlscz
No, sorry, still the same.
It could be some weird problem with my PC (though I ran windows files check and virus check - no problems found).
I can use /silent, or I guess I could transfer files from one of my laptops, or use portable install, so it's not a real problem for me. Still, if it would be interesting for you, I'd try new versions (excerpt, for the next month or so I'll be away).
icewather
@grlscz
It's not your Notebook. I have the same problem.
grlscz
update: 8.9 - no problem
8.4-8.5 still had this problem, 8.6-8.8 didn't try
