Symlinks are copied (when in the FFS Main-Dialog it is set to yes) allthough in the GlobalSettings is set to false.
The GlobalSettings.xml doesn't overwrite this.
Symlinks Problem ...
Why do you think GlobalSettings.xml has something to do with symlinks?
Sorry my mistake.
