Hanging
result42
Ran V6.10 normally a month ago on Windows 8.1. Now, it displays the user interface after launch and starts hanging ("not responding"). Uninstalling and reinstalling did not fix it, nor did rebooting.
Is the problem reproducible? If so, can you create a MiniDump file using Process Explorer (=> right-click on FreeFileSync_x64.exe, Create Dump, Create Full Mini Dump, then compress the file, e.g. via zip) and send it to me via email?
result42
Is the problem reproducible? If so, can you create a MiniDump file using Process Explorer (=> right-click on FreeFileSync_x64.exe, Create Dump, Create Full Mini Dump, then compress the file, e.g. via zip) and send it to me via email?Zenju
Not any more. It's working fine now. Thanks very much for your prompt support!
