Update available notification showing raw html
gavin-r
When I get an 'upgraded version availalble' notification, it is full of html tags.
MAC OSX 10.7 and 10.9
srjones67
Make sure you can get to the internet and the particular location mentioned in the message.
gavin-r
I am connected to the Internet, and I can get to that address.
I see this error on two different machines on separate networks in two completely different locations.
The formatting isn't "pretty" (this has been fixed in 6.11), but the message is correct: time for an update!
gavin-r
Thanks, will check it out. It looked 'prettier' in earlier versions, which is why I raised this.
