Update won't synchronise
petercorser77
I have been happily using v3.7 for many several years - auto update didn't offer anything new, presumably due to version change.
Checked web site & updated to v6.12 on Win 7 Pro 64 bit & Win 8.1 PCs.
In both cases I got a long report about failure to find or read multiple files on first run. Attempting to do any comparison produces a list with zero entries on both sides of the comparison.
I have reinstalled v3.7 on both machines & both run OK.
What did I do wrong?
Peter
What error messages did you get? did you review your sync config including filter settings?
If I remember correctly, ...
FFS v6.x is not backward compatible with FFS v3.x stored sync setting.
Try to recreate your "old" sync setting by defining a new sync in FFS v6.x
(and store this new sync if succesful).
You should still be able to consult your v3.x stored sync settings with any
arbitrary text editor.
petercorser77
Hi Perry
Thanks - that sounds like the problem.
I have tried resetting sync settings, but have not had any success, so far.
I guess a reboot and/or install as administrator may do the job.
