Getting Error Code 2 on start up
Failed install? looks like the file mentioned is missing.
Yes, but is the error message correct?
The error is correct? So this file is indeed missing?
It's not clear what your problem actually is. Is the file missing? or the message incorrect?
I don't have access to your computer, so you'll have to look this up yourself.
Come on, fantasia. Stop nagging and do as instructed/requested.
The error message is extremely clear: your system can not find the file
"C:\Program Files\FreeFileSync\Bin\FreeFileSync_x64.exe"
and Zenju has meanwhile repetitively instructed you to check if said file does exist in said location.
Zenju nor anyone else has access to your computer, so you are the only one who can check this.
