Trying to make this work....Possible?
kbadgley
At my work, we have a shared network drive. We were hoping to be able to put all of our fonts into a folder on that drive, and have it auto insert into the C:\Windows\Fonts folder that way everyone that needs the fonts can have them shared.
Currently it does not work when I try. Is there an issue behind this? (Destination folder "Fonts" does not show up in selector, path has been manually typed in.)
I'd call this a Windows-bug: "Fonts" is not shown in the Windows file picker because it is categorized as a "file". Workaround: Either drag and drop the "Fonts" folder or enter the path manually.
kbadgley
It seems this doesn't install the new fonts.... It looks like it's copied over.... but did not install. (I feel like this is a Windows 7 bug?) Can the RealtimeSync be configured to run a .bat file after it replicates? (Ideally running a .bat that installs the fonts in the folder that are not installed?)
