Enable/Disable folder pair
frwi5432
I'm really into that tool. It makes my life easier. Thanks to all supporting it.
Nevertheless I'd appreciate to be able to enable and disable folder pairs.
It's a great feature to specify several folder structures in parallel.
The possibility to selectively enable and disable them would make a big advantage.
This could avoid removing a folder pair and adding it later again.
Many thanks in advance.
Kind regards,
Willy
malusync
I second that. Now I do workaround adding 'x' to the beggining of source path, which causes warning to appear.
