I use public / private keys to connect to SFTP using port 22. I don't use password, unless only to access private keys. Actual user accounts are not allowed to login using userid / password combination.
Is it possible to add this ability to support SFTP with public/private keys to FreeFileSync?
Thanks for a great product and your time reading this message.
Ivan
NEW FEATURE REQUEST: SFTP - Using Public/Private key
I assume you want to use a PEM or PPK private key + password?
I've added support for authentication via OpenSSL PEM private keys:
http://www.mediafire.com/download/zkfs9bczqn4ib03/FreeFileSync_8.6_beta_Windows_Setup.exe
