In this forum, I am finding that the posting option "Notify me when a reply is posted" is always unchecked.
When we post something, we usually want us to be notify whenever a reply is posted to that.
Whenver I post something, I have to manually check this option, otherwise, if I forget to check it, I post something and then wait for 3-4 days wondering why no one is replying to my post, and then check at forum and find several replies.
So, I guess this option should be TICKED as default, enabling us to get to know of the reply immediately.
I think that is the setting for most of other fora.
Thanks.
Rawat
tick "Notify me when a reply is posted" as default
Who is "we" here? I suppose it is not intended as majestic plural.... When we post something, we usually want us to be notify whenever a reply is posted to that ...vsrawat
Please do not generalize your own preferences.
I for one, treasure that the "Notify me when a reply is posted" option is not marked by default.
However, I can imagine such preference could be defined as a user preference in the User Control Panel,
just like you can define notification preferences for boards you are subscribed to (if any).
yes, found that setting there and ticked that.
Thanks.
Thanks.
