after update to 6.14 can no longer open log files
mithrandir8
Running FreeFileSync on CentOS 7. Have had no trouble until the update to v6.14. My logs used to be written in this format:
Wednesday 2015-02-11 210002.log
Since the update they are now written like this:
Wednesday 2015-02-18 21˸00˸02.log
The new format is preventing me from opening the new logs. I now get errors when trying to open the logs:
"Failed to open /FreeFileSync/Wednesday 2015-02-18 21/800/802.log : No such file or directory"
This is when using the built in text editor from Webmin. I have also tried using gedit from the terminal and cannot open the new log files. Is it possible to change back to the old format?
htismaqe
This will be addressed in the next release:
viewtopic.php?t=1679
mithrandir8
Thank you very much for the info and the link. I was hoping I wasn't the only one having problems with the new format. And that is great that it will be fixed in the next release. :-)
