Is there a way to ignore capitalization in file extensions?
daandehn
My one and only sync job always results in 47 files being hightlighted as conflicts. The only problem is that in one folder the file extension is all caps; in the other the extensions are all lower case. I can just continue to ignore this but it would be neater if it could be fixed.
You can manually set a sync direction (middle grid) to get this resolved.
daandehn
Sorry, but I have no idea what you are talking about.
